As you can see the Rated Operating Capacity below says 1300lbs. The Tipping Load says 2600lbs. I need to lift a pallet of plywood that has 35 sheets that I estimate to be about 1600lbs total off of a semi and bring it to my rear yeard. Is it safe to do. What is the different between tipping load and Rated Operating Capacity? 743 Engine Cooling Liquid Emissions Tier (EPA) N/A Engine Fuel Diesel Horsepower 36 HP Turbocharged Engine N/A Rated Operating Capacity (SAE) 1300 lbs ROC with Counterweight Option N/A Tipping Load 2600 lbs Operating Weight 4720 lbs Travel Speed N/A Travel Speed (2-speed option) N/A Fuel Tank N/A Pump Capacity 11 GPM Auxiliary Std Flow 11 GPM Auxiliary High Flow N/A Length 120.4 in Length with Standard Bucket N/A Width 55.1 in Width (with bucket) N/A Height 75.8 in Height with Operator Cab N/A Height to Bucket Hinge Pin 109 in Reach @ Maximum Height 21.8 in Turning Radius N/A Wheelbase 35.4 in Joystick Control N/A Air Conditioning N/A Backup Alarm N/A BICS System (Interlock) n/a Cab Enclosure N/A Cab Heater N/A Suspension Seat N/A Deluxe Instrumentation N/A Engine Shutdown N/A Hydraulic Bucket Positioning N/A High Flow Option N/A Auxiliary Hydraulics std Bob-Tach Attachment System std Power Bob-Tach N/A Ride Control N/A Horn N/A Chain Size Final N/A
