Bobcat  > General Questions  > Re: Securing Bobcat to trailer
 Author Thread: Securing Bobcat to trailer
Chandler is not online. Last active: 9/20/2013 9:02:17 PM Chandler
Top 100 Poster
Posted: 08/04/2008 12:33 AM
Just wondering what most of you use to secure your Bobcat to the trailer, boomers and chains or straps? I'm not sure what is legal or required by law now for transporting construction equipment. But I see tractor trailers running up and down the road hauling everything that is secured by straps now.
Bobcat 773 Turbo, bobcat 4-n-1 combo bucket w/teeth, Large-light material-bucket, bradco 609 backhoe w/12",18" & 24" buckets, bobcat forks, Grapple, FFC Preparator, boom pole, Bobcat Brushcat, Kubota RTV 900
TriHonu is not online. Last active: 11/24/2014 8:14:22 PM TriHonu
Posted: 08/04/2008 07:47 AM
I use 4 chains with 4 ratcheting load binders.  The load must be secured to prevent forward, backward and sideways movement.  I want DOT to be able to easily see the load is secured.  I don't wish to give them any reason to stop me.  If DOT observes your loader moving on the trailer, you can get stopped for improperly secured load.
Minnesota follows the  Federal Motor Carriers Cargo Securement Rules.
I attended a Trailering Class at Lano Equipment this spring.  DOT conducted the class to cover common questions concerning: licensing, driver requirements, cargo securement, inspections and common issues the inspectors identify during routine stops.
They stated it takes a minimum of 2 tie-downs for the loader plus you have to secure any articulating parts (loader arm).  So their answer was minimum of 3 tie-downs.  Each tie-down must be adjustable so each chain must have a load binder.
If you carry any thing in your bucket (like another bucket), those items also require their own tie-downs.
They discouraged the use of nylon straps, but if you use them you have to place strap protection where a strap crosses any edge that could damage the strap.  They also must be properly sized for the load.  A 2” wide strap has a working load limit of 2000 lbs, 3” is 3000 lbs and 4” is 4000 lbs.  I still occasionally see Bobcats secured to trailers with  the 2” ratchet straps and wonder how long until DOT pops them.  A single Grade 43 3/8 chain has a higher working load limit (5400 lbs) than a pair of 2” straps.
In my opinion, $200 for chains and binders is nothing compared to the cost of the loader or a DOT stop or a lawsuit from losing part of a load.
763, auger, Bradco Backhoe, hydraulic handheld breaker, 4in1 buckets, forks, Industrial Grader, pan grapple, landplane with hydraulic scarifier, snow blower, snow plow, Soil Conditioner, Sweeper, Tilt-Tatch, OTT, U-Digger
73Eldo is not online. Last active: 10/16/2009 9:59:04 AM 73Eldo
Posted: 08/04/2008 08:17 AM
Cool link, a normal person can almost understand it. I always go the obvious overkill method also just in hopes that they wont stop me. I have been using chains for the big stuff. Things I move regularly I make up custom chains so its faster to hook up. For misc. stuff I bought some 7" hooks and put the grabber hooks on them so they can easily hook and adjust to standard chains. Those large hooks have saved me hours of crawling under stuff trying to find a place to wrap chains. They were not cheap but are sure handy. Straps seem to rub through too easy especially when they catch the wind. I pretty much only use them in my enclosed trailer or for quick trips with lumber and such.
perry is not online. Last active: 10/4/2009 7:20:05 PM perry
Posted: 08/04/2008 04:06 PM
I welded hooks to all my attachments, connect short chains to attachment and one long chain through the back of bobcat and tighten with chain ratchet.
Fast and secure.....
Top 100 Poster
Posted: 08/04/2008 07:10 PM
Thanks for the good info. I think I will go with 3/8" chain and binders or rachets.
sterlclan is not online. Last active: 10/18/2014 5:00:47 AM sterlclan
Posted: 08/05/2008 04:39 AM
Ratchet binders work waaaaay better and are less likely to bust your teeth when removing them get good chain and hooks round here they don't like Chinese or Japanese hooks and chain. Better to spend a little now instead of more later.......my 2c....Jeff
The difficult is no problem....................................................the impossible just takes a little longer. Try it........You might like it
Top 100 Poster
Posted: 08/05/2008 05:04 AM
Know where you can find American made chains and hooks?
Posted: 08/05/2008 08:37 AM
There is a safer version of standard load binders called  Safety Lever Load Binders.  The handle is hinged and works like a normal load binder when you close it.
When you open it, the handle swings freely until it is pointed away from the chain.  As you continue to push the handle forward the binder releases without the handle having to move any further forward.
Posted: 08/05/2008 01:43 PM
Thanks for the link on the load binders, I have been looking for some more of that style and no one carries them. My father set up our lowbed back in 85 with those and slowly we keep losing one  etc and I have never been able to find  any more. And the screw ones don't last one the salted roads up here.
Top 100 Poster
Posted: 08/06/2008 05:06 AM
Good info on the binders. Just need to find some good ol American made chains now. I looked at Tractor Supply and they were $69.95 for a 20' long by 3/8" link with hooks with about a 6000 lb. load rating. Don't know if it is made in the u.s.a. I might get one of this size and two about 10' long to boom the Bobcat down.
mllud is not online. Last active: 1/5/2009 5:16:18 PM mllud
Posted: 08/06/2008 10:22 AM
I tried to find a chart on chain working load limits. You have to be careful with D.O.T. rules.The good chains have the grade stamped on them. You need at least a grade 7.  It will be stamped  on the chain. Mike
Most Common Types Of Chain
Stainless Steel Chain
Uses:
Food processing, chemical and marine applications, and wherever non-magnetic, electrically welded, corrosion resistant chain is needed. DO NOT USE FOR OVERHEAD LIFTING. Minimum elongation 15%. Proof tested.
Proof Coil Chain (Grade 30)
Uses:
Excellent general purpose chain of standard commercial quality for all ordinary applications not requiring high strength-to-weight ratios. Frequently used for fabricating tow chains, binding or tiedown chain and logging chains. DO NOT USE FOR OVERHEAD LIFTING. Minimum elongation 15%. Proof tested.
High Test Chain (Grade 40)
Uses:
Designed for use in load binding, towing, logging and other applications requiring higher strength-to weight ratios than System 3. DO NOT USE FOR OVERHEAD LIFTING. Minimum elongation 15%. Proof tested.
Transport Chain (Grade 70)
Uses:
Designed for use in load binding, towing, logging and many applications requiring higher strength-to weight ratios than grade 40. grade 70 meets stringent DOT regulations with smaller chain that is lighter in weight and easier to handle. DO NOT USE FOR OVERHEAD LIFTING. Minimum elongation 15%. Proof tested.
Aluminum Chain
Uses:
Chemical processing, explosives manufacturing, petroleum refining, food processing, landscaping and crowd control, wherever a non-magnetic non-sparking chain is needed. Ideally suited for applications requiring optimum strength-weight ratios and maximum resistance to atmospheric and salt water corrosion. NOT TO BE USED FOR DYNAMIC LOAD CONDITION. DO NOT USE FOR OVERHEAD LIFTING. Proof tested. STANDARD MATERIAL: 5056 aluminum-magnesium alloy.
Grade70 Fishing Chain
Uses:
Designed to accommodate all types of chain need s in the trawling industry. DO NOT USE FOR OVERHEAD LIFTING. Minimum elongation 15%. Proof tested.STANDARD MATERIAL: High strength heat treated steel which resists shock loading and corrosive elements.
System 8, Alloy Chain
Uses:
SPECIFICALLY RECOMMENDED FOR OVERHEAD LIFTING and applications which demand a combination of minimum weights and high working load limits. Elongates in excess of the 15% minimum requirement. Proof tested. STANDARD MATERIAL: Alloy steel, heat treated.
Grade 100
Uses:
25% Stronger than Grade 80 Alloy, Allows downsizing of chain and components resulting in less sling weight and increased mobility. Grade 100 chain Components are avaiable for supply. For detail please contact us by email: sales@tooleegroup.com.cn or tel:86 532 88668543 or fax:86532 82737869
Straight Link Machine Chain
Uses:
General utility farm and animal. DO NOT USE FOR OVERHEAD LIFTING.
Posted: 08/06/2008 10:29 AM
I bought two 20' 3/8 with hooks from this guy two years ago, nothing wrong with them.
http://cgi.ebay.com/ebaymotors/2-CHAINS-3-8-x-20-G70-F-JOHN-DEERE-TRACTOR-SKID-STEER_W0QQcmdZViewItemQQ_trkparmsZ72Q3a570Q7c39Q3a1Q7c66Q3a2Q7c65Q3a12QQ_trksidZp3286Q2ec0Q2em14Q2el1318QQhashZitem180272187304QQitemZ180272187304
Posted: 08/06/2008 10:32 AM
There are two companys I know of that sell d.o.t. chain.
http://www.awdirect.com/
http://www.zips.com/
Posted: 08/06/2008 12:47 PM
my local napa sells u.s. chains........we have a large logging population around here and they are set in their ways...... they stock what sells...... Jeff
Posted: 08/06/2008 08:13 PM
The Grade 70 chain has a flat spot on the side of the link every few links and is stamped  “g7” or “g70” I have never seen any that is stamped where its made and if it marked g7 it meets the requirement. Here if the stamp can't be read they will downgrade you to the lowest rating for that  size of chain as the grade is then unknown.
Same with the hook, g7 should be A ok, but the dot may be predjudice against off shore stuff from china etc.
Top 100 Poster
Posted: 08/08/2008 04:11 AM
I found and purchased at least one hundred feet of grade 70 transport chain at a local Farmers Co-op supply store yesterday. They were wanting to get rid of it because their hydraulic cutter broke down, so thankfully I got a good deal on it. So I'll just need to buy some hooks to make up some lengths of chain. I have a question about cutting. Would I be able to cut the chain with a metal cutting blade on a disc grinder?
Posted: 08/08/2008 05:43 AM
It will cut that like butter. Its not that grade 70 is that tough, its more like grade 30 is about as soft as lead (almost)
 Try to think what lenghts would be handy. For the low bed I use mostly 15' chains, the bocat mostly 10'
But its always good to have one or two longer and shorter. If you have yoour equipment and trairer, Park it on there and measure between the tie down points.
Top 100 Poster
Posted: 08/09/2008 03:16 AM
Thanks! That's what I'll do. The next thing I'll need to do is get or build a box that goes between the gooseneck vertical beams to put the chains and binders in.
Posted: 08/09/2008 04:53 AM
make sure that there is drainage in the box or your stuff will get rusty quick....Jeff
Top 100 Poster
Posted: 08/27/2008 06:30 AM
I tried to order some of these binders but they were out of stock. They didn't say when they would get some more in.
Top 100 Poster
Posted: 08/27/2008 06:32 AM
I was referring to the Safety lever load binders..
Goto to page:  Prev Next
Forums  > Bobcat  > General Questions  > Re: Securing Bobcat to trailer
