Im a newby. I have recently purchaced an old melroe bobcat 642 ,has a ford 1.6 cross flow engine. I noticed the goveror was not working and when I pulled it apart I descovered it had practicly no oil in it! I checked seal bearings and throw mechanism all seem fine and in perfect working order.(seems to be a very simple unit) I refilled the governor put it back on and tried it and still nothing? I then adjusted the throttle/governor linkage as the manual specifies and still nothing. I've had to resort to adjusting the restrictor screw so I can bring the revs up to around 2500rph as aposed to the 1000-1500 I was getting? so dose any one have any ideas why my governor still wont work? wondering if it could be the spring? Has a bit of wear in the spring attatching holes. frustrating ! p.s compression test O.K
