server error
This occured while trying to acess the second page or posts using the bottom link mark next page on the new loader thread in the NH forum
Server Error in '/' Application.
Input string was not in a correct format.
[FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif]Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.FormatException: Input string was not in a correct format.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
Code:
[FormatException: Input string was not in a correct format.]
   System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) +0
   AspNetForums.Controls.Paging.PrevNext_Click(Object sender, EventArgs e) +58
   System.Web.UI.WebControls.LinkButton.OnClick(EventArgs e) +108
   System.Web.UI.WebControls.LinkButton.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +57
   System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +18
   System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +138
   System.Web.UI.Page.ProcessRequestMain() +1292
Version Information: Microsoft .NET Framework Version:1.1.4322.2300; ASP.NET Version:1.1.4322.2300 [/FONT]
Thanks, I'll take a look at it...
Here is another one.
Cannot insert the value NULL into column 'PinnedDate', table 'BobcatDNN.dbo.AdverFRM_Posts'; column does not allow nulls. INSERT fails. Cannot insert the value NULL into column 'TotalPosts', table 'BobcatDNN.dbo.AdverFRM_Forums'; column does not allow nulls. UPDATE fails. The statement has been terminated. The statement has been terminated.
Exception Details: System.Exception: Cannot insert the value NULL into column 'PinnedDate', table 'BobcatDNN.dbo.AdverFRM_Posts'; column does not allow nulls. INSERT fails. Cannot insert the value NULL into column 'TotalPosts', table 'BobcatDNN.dbo.AdverFRM_Forums'; column does not allow nulls. UPDATE fails. The statement has been terminated. The statement has been terminated.
Source Error:
Stack Trace:
Code:
[Exception: Cannot insert the value NULL into column 'PinnedDate', table 'BobcatDNN.dbo.AdverFRM_Posts'; column does not allow nulls. INSERT fails.
The statement has been terminated.]
   AspNetForums.Data.SqlDataProvider.AddPost(Post postToAdd, String username) +1019
   AspNetForums.Posts.AddPost(Post postToAdd) +101
   AspNetForums.Controls.CreateEditPost.PostButton_Click(Object sender, EventArgs e) +1567
   System.Web.UI.WebControls.Button.OnClick(EventArgs e) +108
   System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +57
   System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +33
[/FONT]
Version Information: Microsoft .NET Framework Version:1.1.4322.2300; ASP.NET Version:1.1.4322.2300[/FONT]
owensge
Source Error:
Stack Trace:
Thanks Ken.. Were you trying to Pin? Or reply to a Pin?
Here is another one I got when trying to follow a link I just fixed in this thread.
DIY stump bucket
This is the link.
http://www.skidsteerforum.com/DesktopDefault.aspx?tabid=52&gallerypage=1¤titem=3&path=Root%20bucket%202
Source Error:
Stack Trace:
Code:
   Microsoft.VisualBasic.CompilerServices.DoubleType.Parse(String Value, NumberFormatInfo NumberFormat) +195
   Microsoft.VisualBasic.CompilerServices.IntegerType.FromString(String Value) +97
[InvalidCastException: Cast from string "1¤titem=3" to type 'Integer' is not valid.]
   Microsoft.VisualBasic.CompilerServices.IntegerType.FromString(String Value) +212
   DotNetNuke.TTT_GalleryDispatch.Page_Load(Object sender, EventArgs e) in N:\BobcatDNN\DesktopModules\TTTGallery\TTT_GalleryDispatch.ascx.vb:47
   System.Web.UI.Control.OnLoad(EventArgs e) +67
   System.Web.UI.Control.LoadRecursive() +35
   System.Web.UI.Control.LoadRecursive() +98
   System.Web.UI.Page.ProcessRequestMain() +750
owensge
DIY stump bucket
This is the link.
Source Error:
Stack Trace:
Thanks Ken... That url looks funky. Here's the one I replaced it with: http://www.skidsteerforum.com/DesktopDefault.aspx?tabid=52&gallerypage=0&path=Root%20bucket%202
How did that: ¤titem= get in there? That's what caused the problem...
I don't know, I only worked on the ends of it.
I think that link was mine....don't know where the funny symbol came from I copy and pasted it with firefox thanks Jeff
Here is another one. I got this twice in a row. I save the second post attempt to a email. I can forward to you if you send me yours again. The only thing unusually about it was i used 4 or 5 spaces to separate 2 numbers I did not want to apear as one.
Ken at skidsteer.ca
Source Error:
Stack Trace:
Code:
   AspNetForums.Controls.CreateEditPost.PostButton_Click(Object sender, EventArgs e) +1566
[/FONT]
owensge
Ken at skidsteer.ca
Source Error:
Stack Trace:
Thanks again Ken... I'll take a look at that right now...
Object cannot be cast from DBNull to other types.
Exception Details: System.InvalidCastException: Object cannot be cast from DBNull to other types.
Source Error:
Stack Trace:
Code:
[InvalidCastException: Object cannot be cast from DBNull to other types.]
   System.DBNull.System.IConvertible.ToInt32(IFormatProvider provider) +48
   System.Convert.ToInt32(Object value) +36
   AspNetForums.Data.SqlDataProvider.PopulateThreadFromSqlDataReader(SqlDataReader reader) +560
   AspNetForums.Data.SqlDataProvider.GetAllThreads(Int32 forumID, Int32 pageSize, Int32 pageIndex, DateTime endDate, String username, Boolean unreadThreadsOnly) +657
   AspNetForums.Threads.GetAllThreads(Int32 forumID, Int32 pageSize, Int32 pageIndex, DateTime endDate, String username, Boolean unreadThreadsOnly) +483
   AspNetForums.Controls.ThreadView.OnPreRender(EventArgs e) +390
   System.Web.UI.Control.PreRenderRecursiveInternal() +62
   System.Web.UI.Control.PreRenderRecursiveInternal() +125
   System.Web.UI.Page.ProcessRequestMain() +1499
This was when i tried to access the Bobcat/general questions area.[/FONT]
mllud
Source Error:
Stack Trace:
I kept getting this when trying to open a thread. It was under Bobcat [general questions] posted at 7;40 pm on 5/12/08
Source Error:
Stack Trace:
Code:
Source Error:
Stack Trace:
While trying tomove the 1st Myths post from Suggestions to Myths
Source Error:
Stack Trace:
Code:
   AspNetForums.Controls.WhereAmI.RenderPostsMenu() +92
   AspNetForums.Controls.WhereAmI.InitializeSkin(Control skin) +1423
   AspNetForums.Controls.SkinnedForumWebControl.CreateChildControls() +25
   System.Web.UI.Control.EnsureChildControls() +100
   System.Web.UI.Control.PreRenderRecursiveInternal() +38
[/FONT]
mllud
Source Error:
Stack Trace:
Im still getting that error on two of the babcat forums. Bobcat [General Questions]and Bobcat[General Repairs]. Mike
owensge
All the time or randomly? Never mind. Looks like there's a problem. I'm going to try a reboot and see if that clears things up...
Druing a reply to http://www.skidsteerforum.com/DesktopDefault.aspx?tabid=54&frmView=ShowPost&PostID=15988
Source Error:
Stack Trace:
Code:
   AspNetForums.Controls.CreateEditPost.PostButton_Click(Object sender, EventArgs e) +1568
[/FONT]
